Flex 6000 Series Extended Transmit Module
I have the Flex 6400 with the Extended Transmit Module for MARS operation. Will this work with module work with the new 8000 series of radios? Thanks.
  • David Decoons, wo2x
    I cannot answer if the module will be plug in compatible with new hardware but you will need a new TURF file for the new radio.
    Also more importantly, you should request a region locked TURF for the 6400 before selling it.
    Note, and just a reminder, Flex will only sell an extended TX module if the person requesting it provides a copy of their MARS/SHARES license.
    73 Dave wo2x
  • W9MO
    W9MO Member ✭✭
    Thanks for the reply, but I was hoping Flex would chime in and give me the answer.
    Yes, you can use the same Extended TX module. You will need to reapply for a new TURF file.
  • snowman
    snowman Member
    edited August 2024
    Sorry, off topic.
