Announce: experimental CAT/DAX clients for Linux
I am up and running with WSJT-X and GridTracker without issue. I am having trouble getting CQRLog to run and interface with the radio. I have attached a screen shot of my settings. When I apply these settings, I get multiple instances of: Handler returned error error="required max 0 args, got 1" cmd=["short:f","mv"]
I would appreciate any ideas on how to get this running. I know that I can populate the log from WSJT-X, but I like to operate USB as well. I would like to operate the 6400M with just the log.
Thanks.0 -
Awesome work!
FYI, it looks like the version of pipewire inside Ubuntu 24.04 ("1.0.5-1ubuntu1" per apt) still suffers from high receive latency like what was mentioned back in September. Fortunately, starting pavucontrol before starting nDAX is still a viable workaround.
Also, if you use SmartSDR for Mac, you may need to use $'\x7f' instead of spaces for your station name. I reported that over on GitHub (https://github.com/kc2g-flex-tools/nDAX/issues/14) and hopefully the fix for that will make it into the next releases of nDAX and nCAT.
- 637 The Flea Market
- 144 SmartSDR+
- 432 SmartSDR for Mac
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 57 FlexControl
- 932 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
