Announce: experimental CAT/DAX clients for Linux
12346»
  • AI7FP
    AI7FP Member ✭
    I am up and running with WSJT-X and GridTracker without issue. I am having trouble getting CQRLog to run and interface with the radio. I have attached a screen shot of my settings. When I apply these settings, I get multiple instances of: Handler returned error error="required max 0 args, got 1" cmd=["short:f","mv"]
    I would appreciate any ideas on how to get this running. I know that I can populate the log from WSJT-X, but I like to operate USB as well. I would like to operate the 6400M with just the log.
    Thanks.
  • AI7FP
    AI7FP Member ✭
    Below is the correct configuration for CQRlog to work correctly with nCAT.
  • themindiswatching
    Awesome work!
    FYI, it looks like the version of pipewire inside Ubuntu 24.04 ("1.0.5-1ubuntu1" per apt) still suffers from high receive latency like what was mentioned back in September. Fortunately, starting pavucontrol before starting nDAX is still a viable workaround.
    Also, if you use SmartSDR for Mac, you may need to use $'\x7f' instead of spaces for your station name. I reported that over on GitHub (https://github.com/kc2g-flex-tools/nDAX/issues/14) and hopefully the fix for that will make it into the next releases of nDAX and nCAT.
