Can I use two Flexradios with different s/w versions?
I've currently got a 6300 and it's on 2.10.1. When my new 8600 finally gets here (probably next year sometime) will I be able to use both radios? Not at the same time, of course. Run 2.10.1 when I want to use the 6300 and run whatever the new 8600 comes with when I want to run that radio.
Best Answers
The only difference will be the version of SmartSDR you use on your pc. You will need the correct version for each radio. You "should " be able to have two versions of SmartSDR on your pc without any conflicts.
Hi Dave, Yes you can. I keep two versions (V2.12.1 and 3.7.4) on my computer so that I can go back and forth to test my homebrew TeensyMaestro and a couple of PC-based utilities that I wrote.
When the new version of SmartSDR (for your 8000 series radio) becomes available, install it on the same PC as your 2.10.1 software. It will set up 3 shortcut icons on your desktop. The shortcuts will contain the version number so that you can tell which one to click to start SmartSDR for the radio that you want to operate.
Version 2.12.1 is the latest V2 software - I recommend upgrading your 6300 to that, it is a good, stable version.
Thanks, James!
Thanks, Len. I'll do that upgrade soon.
73, Dave
You can run different versions of SmartSDR at the same time, but you can only run 1 version of CAT or DAX at the same time. This may be a limiting factor.
Thanks, Mike.
73, Dave
- 637 The Flea Market
- 144 SmartSDR+
- 432 SmartSDR for Mac
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 57 FlexControl
- 932 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
