How to setup wsjtx ... -rc6 for Flex 6400
WØYVA
Can't get CAT to work. Worked fine with 'standard' wsjtx. It worked when using Kenwood 2000 as the rig. Using Kenwood or Flex 6000 doesn't work. What am I missing? Thanks!!
Best Answers
I have always chosen:
Flex 6xxx radios
network server 127.1.1.1:6003First I created a CAT from scratch with TCP on slice A
It works really well
Another way is to use SliceMaster and it will then launch WSJTx for you. As well, it makes it easy to run multiple slices as the same time.
Exactly! I finally figured it our … needed to add the name of the network server. Thanks, Piero. Bob
felice di essre stato di aiuto almeno una volta e non usare le esperienze dei colleghi
73 IZ1XEE
- 657 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 295 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 467 Remote Operation (SmartLink)
- 809 Peripherals & Station Integration
