How to setup wsjtx ... -rc6 for Flex 6400
Can't get CAT to work. Worked fine with 'standard' wsjtx. It worked when using Kenwood 2000 as the rig. Using Kenwood or Flex 6000 doesn't work. What am I missing? Thanks!!
Best Answers
I have always chosen:
Flex 6xxx radios
network server 127.1.1.1:6003First I created a CAT from scratch with TCP on slice A
It works really well
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsAnother way is to use SliceMaster and it will then launch WSJTx for you. As well, it makes it easy to run multiple slices as the same time.
Exactly! I finally figured it our … needed to add the name of the network server. Thanks, Piero. Bob
felice di essre stato di aiuto almeno una volta e non usare le esperienze dei colleghi
73 IZ1XEE
- 419 Community Topics
- 718 The Flea Market
- 226 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
