Configuration of WSJT-X for Flex6000/8000 Radios
Ken Wells
Community Manager admin
The Tutorial Document for Simple configuration of WSJT-X and JTDX has been updated:
Configuring WSJT-X for the Flex-6000 Series – FlexRadio
5
As always, a great tutorial.
TNX OM Ken
Hi, I changed from WIN10 to a WIN11 PC and now am a bit confused about the audio (DAX) settings in Windows for WJST-X to get if working with 6400. Any hints what I should change in audio settings from default values if any? Especially the Volume mixer Apps part is a bit confusing as it is something different vs WIN10.0
The Windows volume level mixer settings should remain at default for DAX virtual devices.
Set DAX TX level to 48 which should put TX and power slider in WSJT-X at max. TX level should be right at zero.
Set the DAX RX audio to around 34. This should give a receive level in WSJT-X about 50 when no signals are present.73 Dave wo2x
OK thanks. Yes I had those DAX TX and RX levels configured roughly as you propose, only wondering about audio settings on Windows side. But ok those are fine with default settings.
73 Pekka, OH2TA0
- 311 Community Topics
- 569 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 386 SmartSDR for Mac
- 253 SmartSDR for iOS
- 241 SmartSDR CAT
- 176 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 113 FLEX-8000 Signature Series
- 888 Maestro
- 50 FlexControl
- 845 Genius Products
- 435 Power Genius XL Amplifier
- 297 Tuner Genius XL
- 113 Antenna Genius
- 267 Shack Infrastructure
- 188 Networking
- 428 Remote Operation (SmartLink)
- 132 Contesting
- 687 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 916 Third-Party Software
