Audio Stream interupt Windows SDR
MAtthias O.
Member ✭
Hello, I have a problem
m using Windows and Flex6400 I have dropouts in the transmission. It sounds as if a squelch is switched on and the limitation switches on and off.
I have this with two 6400 devices.
The problem does not occur when using a Mac.
The network is green and says excellent
Do you know the problem?
dl5qy mo@oesterwinter.net
This does sound like some sort of network communication issue. Since the MAC works, it could be on the NIC card of the PC. Could it be a bad Mic cord? There really isn't a lot of information here to give you an exact solution, just some educated guesses.
You may wish to open a support ticket.
Hi Mike only in Reciving have this problem0
I would open a support ticket and make sure you supply a video with the problem happening.
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 966 Maestro
- 938 Genius Products
