Audio Stream interupt Windows SDR
MAtthias O.
Member ✭
Hello, I have a problem
m using Windows and Flex6400 I have dropouts in the transmission. It sounds as if a squelch is switched on and the limitation switches on and off.
I have this with two 6400 devices.
The problem does not occur when using a Mac.
The network is green and says excellent
Do you know the problem?
dl5qy mo@oesterwinter.net
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThis does sound like some sort of network communication issue. Since the MAC works, it could be on the NIC card of the PC. Could it be a bad Mic cord? There really isn't a lot of information here to give you an exact solution, just some educated guesses.
You may wish to open a support ticket.
Hi Mike only in Reciving have this problem0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI would open a support ticket and make sure you supply a video with the problem happening.
- 110 Aurora
- 322 Shack Infrastructure
- 227 Networking
