Cannot connect toTGXL and PGXL utility
When I start either TGXL utility or PGXL utility or both on the PC, neither one shows a connection to the physical device. Help, thoughts? I was on the air two nights ago and had no issues then.
Don - kx9q
I was able to get the PGXL utility working after I clicked on the "gear" in the utility. TGXL still will not connect.
Don - kx9q
Can I change the antenna selection without the use of the TGXL utility?
Don -kx9q
try resetting your router
Peter
I did but no success.
is the network light flickering on the TGXL?
In the router device table does the TGXL show up?
If the answer to either is no I d open a support ticket
Peter
Yes to both questions. I opened a helpdesk ticket.
Don
Today, I decided to delete the TGXL utility, reboot, and install the current version (same version as the one I deleted) of TGXL from the Community web site. To my surprise when I started the TGXL utility (newly installed) it was able to connect to the TGXL.
that’s unusual but I’m glad you got it figured out!!
Peter
Sounds like your antivirus/firewall software did an upgrade and blocked the communications to the TG XL. By reinstalling the app, it recreated the firewall rules.
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
