Cannot connect toTGXL and PGXL utility
DonS
DonS Member ✭✭✭
When I start either TGXL utility or PGXL utility or both on the PC, neither one shows a connection to the physical device. Help, thoughts? I was on the air two nights ago and had no issues then.
Don - kx9q
  • DonS
    DonS Member ✭✭✭
    I was able to get the PGXL utility working after I clicked on the "gear" in the utility. TGXL still will not connect.
    Don - kx9q
  • DonS
    DonS Member ✭✭✭
    Can I change the antenna selection without the use of the TGXL utility?
    Don -kx9q
  • W2PP
    W2PP Member ✭✭✭
    try resetting your router
    Peter
  • DonS
    DonS Member ✭✭✭
    I did but no success.
  • W2PP
    W2PP Member ✭✭✭
    is the network light flickering on the TGXL?
    In the router device table does the TGXL show up?
    If the answer to either is no I d open a support ticket
    Peter
  • DonS
    DonS Member ✭✭✭
    Yes to both questions. I opened a helpdesk ticket.
    Don
  • DonS
    DonS Member ✭✭✭
    edited July 2024
    Today, I decided to delete the TGXL utility, reboot, and install the current version (same version as the one I deleted) of TGXL from the Community web site. To my surprise when I started the TGXL utility (newly installed) it was able to connect to the TGXL.
  • W2PP
    W2PP Member ✭✭✭
    that’s unusual but I’m glad you got it figured out!!
    Peter
  • David Decoons, wo2x
    Sounds like your antivirus/firewall software did an upgrade and blocked the communications to the TG XL. By reinstalling the app, it recreated the firewall rules.
