Blank login window in Smartlink
carsco
I've a Windows PC where I cannot see inside login window.
When I clink on "Log In" I see this:
What I can do?
I created a Helpdesk ticket for you.
Many thanks!
Hello carsco and Mike!
Has there been any development with carsco's issue in his posting? I've had this same exact problem since April 2023, when Ken & I tried several things back and forth under ticket #58141 and never really found the answer.
I spoke to someone at Dayton 2024 as well--forget the name. He thought it might be some access issue to the SmartLink server but I didn't write down the IP address he said. I saw other postings as well here asking about the IP addresses but no replies. I tried removing software I thought might be interfering with the network and that's not it.
This is literally the only software I've tried that does not work on my PC. Others can say it's my PC (or carsco's) but now that someone else has the same problem--it's not just my/our PC.
If you find out something please post it here so we can all solve it. Thanks!0 -
I haven't investigated further and I still have the same problem on the same machine.
I THINK it's a default browser problem on the PC.
Try installing Chrome (for example) and making it the default browser.
If Chrome is the default browser, choose another one.
Also try completely resetting the browser settings.
Smartlink access is web-based and what you see in the window comes from a browser.
If the browser has reasons not to work, Smartlink doesn't work either.
Let me know.
Bye.0 -
@Krusher Please open a support ticket or follow up again.
Thanks carsco and Mike for your update. For now I've deleted the SSDR software since I've been changing the Sound settings in the control panel; sometimes I will get a BSOD from the portcls.sys driver. Without SSDR, computer is 100% solid and does not BSOD. I don't have a FLEX myself and can use RustDesk as a work-around for remote control.
I would try another ticket Mike, but since I don't know the name of that "one guy" whom knew the IP address of the SSDR server, I generally get the reply back about clearing out your browser cache, resetting the network settings, the generic stuff. That probably works for most people, except for carsco and myself.
I'll check back here occasionally to see if someone has figured it out, or if FLEX comes up with some future patch. The answer is there :) we just haven't found it yet.1
- 361 Community Topics
- 620 The Flea Market
- 8K Software
- 36 SmartSDR+
- 6.3K SmartSDR for Windows
- 416 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 224 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 983 Third-Party Software
