can SmartSDR keep panadapter with a 4m Transverter persistent
need your help ..Im new to profiles and persistent state.
Flex 6600 SmartSDR V 3.7.4 Windows 11
my desired state would be
- One panadapter with a slice receiver A for 6m ANT1/ANT1 and
- another panadapter with a slice receiver B for 4m via transverter XVTA/XVTA
When I close and start SmartSDR, only panadapter A 6m shows up.
When I do the same with two panadapters and each one has a slice receiver both on 6m
After close and start smartSDR, both panadapters and slice receivers are startet.
When I only have one panadapter with one slice receiver on 4m via transverter
close and start SmartSDR all is fine, I get my panadapter with all settings for 4m via transverter started
My question is, how ca I get my desired state with persistent settings without the need of loading a global profile I have saved before.
many thanks for your help
Remo es HB9SHD
P.S.
I have read the manual, but because I'm not native english, I did't understand all and, even when translated with deepl I do not understand it fully.
Hi
Build the layout you wish and then save it as a Global Profile.
Then, when you want that layout again, recall (or Load) the Global Profile.
See if that works for you.
Hi Mike
many thanks for your answer.
This I did already and yes I can save and load the profile everytime I start SmartSDR SW.
But my question is, can I achive the desired state persistent, without the need to load a profile everytime I start the SW?
and why both panadapters and both slice receiver can be persistent when both for example are on 6m?
When both are on 6m I just close and start SmartSDR SW without the need of manually loading a profile?
Anyway, I have some other issues as well, probaly I open a ticket on servicedesk.Again many thanks for your reply.
Remo es HB9SHD0
- 651 The Flea Market
- 154 SmartSDR+
- 50 Aurora
- 964 Maestro
- 938 Genius Products
