Com ports not found?
Hi folks,
I have N1MM+ configured to talk to my Flex 6400 via TCP ports. However, I sometimes get a message from N1MM+ saying that it can't find com port 1001 (or similar) and when that happens, N1MM+ no longer tracks the frequency of the slice. I can regain full functionality by restarting N1MM. I have, I think, followed the various steps that VA3MW an others have published here on how to do the setup, and everything works just fine with the exception of this particular annoyance. I have gone a full 48 hour contest (not that I'm operating 48 hours) without it happening, or like yesterday, it happened 3 or 4 times in about 8 hours.
Does anyone have any insights into what I may have mis-configured?
Pierre VE3KTB
Can you post screen shots of both your N1MM radio configurer and SmartSDR CAT. It might help to see if I can see anything that might be weird.
Hi Mike,
Sure. I think these are all of the com port related windows. Let me know if you want to see something more.
Thanks and 73,
Pierre VE3KTB
Ps. I know that the 6400 can't really do SO2R. I configure it this way so that I can do in-band S&P during contests on those occasions when I try running.
Forgot this one …
that is pretty much what I use.
Well, I did my best to copy what you had posted previously :-)
Thanks for checking it over!
Pierre VE3KTB
It sounds like a N1MM issue, but it might be hard to prove. I would ask on the N1MM group and see if anyone else sees the same issue.
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 270 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
