Operating TGXL and PGXL with ICOM-7300. Get Rf Early on PGXL
I was checking with another ICOM/TGXL/PGXL user who informed me that the configuration I was given by FLEX was incorrect. I was told by Flex to have the CIV and the PTT from Icom-7300 go to the TGXL and so on (see above). This is not correct—rather, it produced "RF Early "errors on the PGXL in addition to a great deal of frustration. However, when I reconfigured the setup so that that CI-V and the PTT from the ICOM-7300 go first to the PGXL (with the "PTT IN" on the TGXL connected to the PGXL "PTT OUT," everything began to work properly. Now the PGXL screen shows C-IV and the TGXL displays PGXL. No more errors have been encountered. Everything is now performing fine!
Made no difference for me with my K4. Still getting the RF early and other faults. Nice try though…tnx
be extremely careful about keying the amp before the TGXL. They warn you that you may lose the finals in the amp. The transition time for the TGXL is quite long.
I too get early RF warning on the PGXL screen even though I have the PTT delay set at the max of 30mS in the 7300 settings. From the postings I have read above I am not sure that I see a definitive answer to this problem. Can someone from Flex chime in here?
I would recommend you connect your PTT to the TGXL, then the PGXL and then the radio.
I think the 7300 has a TX Delay setting. Try setting that to Maximum?
Mike is correct. Do not hook the PTT to the amplifier first. PTT should go to the tuner first.
if the TX delay is in adequate get a sequencerPeter
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
