AGXL freq limit?
can the AGXL allow 2m and higher to pass though?
Jim
wu5e
    Hi Jim, it's only rated to 6 meters. You would have to test it to see if it is usable at 2 meters.
    No recommended. I suspect if you sweep it (use a MiniVNA), you'll find the path loss is over 1db.
  • James Kennedy-WU5E
    James Kennedy-WU5E Member ✭✭✭
