how do you hook up a Power Genius XL to a ic-7300 radio with a Tuner Genius XL 1x3 tuner ?
poopy
Member ✭
Does it help to see
Plus from Flex: https://helpdesk.flexradio.com/hc/en-us/articles/360042472572-Interfacing-a-PGXL-to-an-Icom-Exciter-using-the-CI-V-Interface
You need to run a mono 3.5 mm male to male cable from the radio CI-V out to PG XL side A CI-V in.
Radio PTT out to PTT A in on amp.
Connect coax from radio Ant 1 to PG XL Drive A.
If you have an external wattmeter and/or tuner, the output of the PG XL goes to the wattmeter, then tuner, then antenna.
Set radio TX Delay to 30 ms.
In PG XL utility, on CAT/CI-V tab, check A side, select Icom and set baud & CI-V address to match radio’s baud & CI-V address. Default CI-V address for the 7300 is 94. Default baud rate is auto so set amp to 9600 baud.
Have fun!
Dave wo2xPresale Technical Support
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 61 Aurora
- 974 Maestro
- 949 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 145 Amateur Radio Interests
