How do I interface both PGXL and TGXL to an Icom IC-7300
Ken D'Alessandro
Instructions abound for connecting the PGXL to an Icom IC-7300 and there are also instructions for connecting the TGXL to an Icom IC-7300. Connecting both is a problem for me since the 7300 has only one Remote (CI-V) output and both the PGXL and the TGXL want to be connected to the Remote (CI-V) output of the 7300.
Facing exact same issue. I've read we have to get a CT-17 from ICOM which will allow more than one CI-V line to be run?0
I discovered that the latest version of the TGXL firmware allows the TGXL to follow the PGXL over the Ethernet connection. The TGXL gets its band/frequency data from the PGXL. This feature is implemented in the setup menu. This solves the problem. In addition VE2DX makes and sells a line of CI-V breakout Hubs. I bought one and it seems to work well.
