Why is Samrt SDR suddenly forcing me to use Smartlink when the radio is in the shack like it always
Been using my radio locally in my shack and occasionally on the road via Smart Link
However never had the software Version 3.7.4 force me to locally use Smart Link
Windows machine no recent changes in the shack
KG5VK
Hi Steven, that probably indicates loss of connection with the radio. It could be any ethernet cable or piece of network gear.
I would start troubleshooting by connecting your computer directly to the radio. If this works, it establishes that the computer, SmartSDR, the radio and the cable are all ok.
If that is all ok, power down all of the network gear (router, switch, etc) and power them back up to see if that solves it.
If the direct connection does not work, then I would shut it all down, reboot the computer and do a factory reset on the radio (export your profiles first). When the radio is done with the reset, start SmartSDR.
If it still doesn't work, then it is time to submit a help desk ticket.
It sounds like your radio and your computer are on 2 different networks.
Any chance you added a mesh or a range extender?
If you can tell us the IP address of the computer and the IP address of the radio, it might start to tell part of the story.
- 391 Community Topics
- 665 The Flea Market
- 171 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 66 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
