Heil Pro 7 -Maestro C - 6400
Just got the rig on the air yesterday. Working my way through the modes. Now SSB.
Problem: No SSB transmit. Using Pro 7 headset and plugged into C. Have audio in headset but Mic is no go.
Hi Richard,
Unfortunately there are a bunch of threads here on this already. Check this one just below yours here:
Good Luck and 73, Russ KR6W
The Heil Pro7 has a TRS plug. I get audio in but nothing audio out. I checked out many of the posts on the subject. Most of the answers were either incomplete or terminology did not apply to the C.
TRSS
Hi Richard,
Just read through the post I provided. It specifically addresses the TRRS, TRS and TS problems with the Heil Pro7 used with the Maestro C. You need to either build or buy the adapter described.
Russ KR6W
Like this?
exactly, this one should work indeed0
Let me document some of my relevant settings:
Using the Maestro C Y Cable Kit:
The TRSS male on the Heil Pro 7 went into the female connector with the headset label
The 1/8" on the Heil went to PTT on Model C
M-HDST selected in the TX Menu, VOX Selected, MON selected, Mic is Default, TX: SO2R_TX1
Profiles/MIC Profiles = Default
Phone/CW screen: Bias=off,
That's It! Audio out is ok…Using MOX to xmit NOTHING.
Any help would be much appreciated.
Maybe some more information from me is required.
The PRO 7 has a TRSS mic/audio plug
The PRO 7 has a 1/8 male ptt plug
I have the Maestro C Y cable kit
The 1/8 Male TRSS from the C Y cable is in the Headset jack
The PRO TRSS is in the Y adapter female with the little headset marking
The PRO PTT plug is in the other female of the Y connector
Phone/CW menu - Bias Off
TX Menu- M-HDST, Mic Default, TX Default
Hope that helps
- 651 The Flea Market
- 50 Aurora
- 965 Maestro
- 938 Genius Products
