Heil Pro 7 -Maestro C - 6400
Richard Zalewski
Richard Zalewski Member ✭✭
Just got the rig on the air yesterday. Working my way through the modes. Now SSB.
Problem: No SSB transmit. Using Pro 7 headset and plugged into C. Have audio in headset but Mic is no go.
  • Russ Ravella
    Russ Ravella Member ✭✭✭
    Hi Richard,
    Unfortunately there are a bunch of threads here on this already. Check this one just below yours here:
    Good Luck and 73, Russ KR6W
  • Richard Zalewski
    The Heil Pro7 has a TRS plug. I get audio in but nothing audio out. I checked out many of the posts on the subject. Most of the answers were either incomplete or terminology did not apply to the C.
  • Richard Zalewski
    TRSS
  • Russ Ravella
    Hi Richard,
    Just read through the post I provided. It specifically addresses the TRRS, TRS and TS problems with the Heil Pro7 used with the Maestro C. You need to either build or buy the adapter described.
    Russ KR6W
  • F4BPO
    F4BPO Member ✭✭
    exactly, this one should work indeed
  • Richard Zalewski
    Let me document some of my relevant settings:
    Using the Maestro C Y Cable Kit:
    The TRSS male on the Heil Pro 7 went into the female connector with the headset label
    The 1/8" on the Heil went to PTT on Model C
    M-HDST selected in the TX Menu, VOX Selected, MON selected, Mic is Default, TX: SO2R_TX1
    Profiles/MIC Profiles = Default
    Phone/CW screen: Bias=off,
    That's It! Audio out is ok…Using MOX to xmit NOTHING.
    Any help would be much appreciated.
  • Richard Zalewski
    Maybe some more information from me is required.
    The PRO 7 has a TRSS mic/audio plug
    The PRO 7 has a 1/8 male ptt plug
    I have the Maestro C Y cable kit
    The 1/8 Male TRSS from the C Y cable is in the Headset jack
    The PRO TRSS is in the Y adapter female with the little headset marking
    The PRO PTT plug is in the other female of the Y connector
    Phone/CW menu - Bias Off
    TX Menu- M-HDST, Mic Default, TX Default
    Hope that helps
