PGXL erroneous high SWR indicated
I’d say that you should open a support ticket
Peter
Yeah, I guess. 😪
I had the same thing. Mine is now in for service. They are slated to look at it in another week— about 3-4 weeks after they received it.
So get that ticket open and it get it sent in sooner than later if it has a problem.
Rudy
Can you describe your antenna system? It might be that something is breaking down at full power. The PGXL is very very fast at detecting transient issues.
I had the same problem on 160M. Turns out it was water in my coax and a connector.
I replaced the coax and couplers with new Amphenol ones and the problem went away.
I've substituted a dummy load for an antenna but results were the same. In the meantime I've done a lot of trouble shooting, worked via emails with tech support and, finally, shipped the PGXL to Flex.
Incidentally, I experienced the problem you describe with another rig at another time and learned, the hard way, that out of spec hardware is sometimes disposed of at ham flea markets rather than getting dumped in the circular file.
Thank you for commenting.
Rudy
Thanks.. that is a great data point.
- 651 The Flea Market
- 154 SmartSDR+
- 50 Aurora
- 964 Maestro
- 938 Genius Products
