Question about RX inputs on 6600
KI5RLR
When using a receive-only antenna located very close to a transmit antenna, should an RF limiter be placed in the RX antenna feedline to prevent damage to the radio? Or do the RX inputs have built in protection?
Clif
That is always a good idea. They are protected to vary large signals (detail in the hardware manual).
If using a Beverage, then yes as they are good a picking up large ground static so you do need some way to discharge that.
A simple 'hack' is to add an NE62 Neon bulb across the line, if you can find one.
Thanks Mike. I will have to look into the Neon bulb method. I will probably use something off the shelf like the DX Engineering 'Receiver Guard'.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
