6600 Ordered!! Need some advise!
On the PC located with the 6600, you would run your digital programs as well as CAT and DAX. On your PC that is with you, you would run SmartSDR. You only need to run CAT on the PC by you if you are running an app there as opposed to running it on the PC by the rig. I would only run the digital programs on the PC by the rig.
Setting up CAT and DAX on the computer by the rig is no different that the setup that you would use when operating locally to the radio. The SmartSDR Software User Guide has the info that you need for set up.
I use TeamViewer or AnyDesk to control the PC by the rig. I can run my logging program (N3FJP) on either PC. When I am up camping, I usually run the logger at the rig so that I get DX spots without overloading my cell phone hotspot with the additional network traffic.
Thanks Len!!0
you can install SmartSDR on remote PC/Laptop with CAt and DAX, eliminating need for TeamViewer or VPN.
Either way. using SmartLink compresses the VITA49 data to use less bandwidth.
Dave wo2x0 -
Do not try to do it all at once or you'll just frustrated.
Get to know the radio first, how to adjust AGC-T, get on the air on SSB and then Digital.
This playlist on YouTube is a must watch.
Thanks!!0
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 984 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 837 Peripherals & Station Integration
- 146 Amateur Radio Interests
