Can't transmit
mike perry
I just got home from 6 months operating my 6400M remote with my Maestro. I cant get the 6400M to transmit and I have to use the Maestro to transmit. When I check profiles it shows the Mic profile correct and transmit profile as SO2R-TX1. What am I doing wrong. Everything was OK before I wnnt remote.
when I return to the local station I find the DAX TX stream button is "Yellow". Clicking that box causes it to go "Blue" and all is good again.
I'm unsure why this occurs.
If the Maestro works and the PC does not (I assume that is what you mean) then you may have to delete the .ini files on the PC.
If that doesn't fix it, open a support ticket.
BTW, doesn't TX needs a bit more description please. Can you tell what works and what doesn't.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
