Can't transmit
mike perry
I just got home from 6 months operating my 6400M remote with my Maestro. I cant get the 6400M to transmit and I have to use the Maestro to transmit. When I check profiles it shows the Mic profile correct and transmit profile as SO2R-TX1. What am I doing wrong. Everything was OK before I wnnt remote.
when I return to the local station I find the DAX TX stream button is "Yellow". Clicking that box causes it to go "Blue" and all is good again.
I'm unsure why this occurs.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIf the Maestro works and the PC does not (I assume that is what you mean) then you may have to delete the .ini files on the PC.
If that doesn't fix it, open a support ticket.
BTW, doesn't TX needs a bit more description please. Can you tell what works and what doesn't.
- 996 Maestro
