FHM-3 connection
Check the following:
- The RCA connector on the hand mic is connected via the adapter to the PTT plug on the Maestro
- You have a TX Slice not selected (RED TX button)
Let us know..73
I have the FMH-2 mic and can't get it to work with the Y-Cable on Maestro C. Is the FMH-3 the only flex mic that works with the Y-Cable?
We only tested with the FHM-3. I don't have a 2 to test with.
However, I think there is a slight cable difference between the 2 and the 3.
When using the FHM-3 and the Y cable:
- M-HDST selected on the Maestro C
- BIAS turned on in the Phone/CW settings
- USB or LSB mode
- TX DAX turned off
The FMH-2 doesn't work with the y-cable.
Thanks. This is likely why it was not on the recommended Mic list.
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
