smartsdr - maestro
I have been using my maestro C for a couple weeks now. Very nice.
Prior i used my pc for 3 years no problem 6400. I have a bit cable set to control my antennas worked perfect until i controlled them from the maestro. I wanted to use the computer today and the USB cable option will not even start. nothing. I went back to the maestro and USB bit cable works fine. any ideas ?
73 WU3X Keith
The BIT cable is part of the radio and if it can't be seen on the Maestro then the radio can't see it either.
I would open a support ticket.
thanks mike. It worked fine on the radio until i started using the maestro. now it only works on the maestro. I didn't explain well. Ill submit a ticket if you think that would be better.
Thanks for your reply
73 W3UX keith
- 394 Community Topics
- 670 The Flea Market
- 176 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 80 Aurora
- 321 FLEX-8000 Signature Series
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
