smartsdr - maestro
I have been using my maestro C for a couple weeks now. Very nice.
Prior i used my pc for 3 years no problem 6400. I have a bit cable set to control my antennas worked perfect until i controlled them from the maestro. I wanted to use the computer today and the USB cable option will not even start. nothing. I went back to the maestro and USB bit cable works fine. any ideas ?
73 WU3X Keith
The BIT cable is part of the radio and if it can't be seen on the Maestro then the radio can't see it either.
I would open a support ticket.
thanks mike. It worked fine on the radio until i started using the maestro. now it only works on the maestro. I didn't explain well. Ill submit a ticket if you think that would be better.
Thanks for your reply
73 W3UX keith
- 390 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 947 Genius Products
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
