Loosing CAT ports nr after reboot
Hi
Since a couple off week, after installing the latest version of smartsdr, I am loosing the device nr for the cat ports.
Checking with CommNameArbiterTool, the ports are present but no Kernel name and therefore not recognized by my programs like Logger32 JTDX etc.
I have to remove the ports from CATSDR close CAT and start again to create the ports.
Is this a known problem?
Didier (****)
F6DXE
    This is a windows problem. Please open a support ticket.
  • Didier F6DXE
    Didier F6DXE Member ✭✭
    Thank you for the answer Mike. I will contact them.
    btw, I like your videos.
    Didier (****)
  • Martin_G4ENZ
    Martin_G4ENZ Member ✭✭
    Mike - Do they have a work around or are they just collecting numbers?
    They have a procedure to resolve it.
    Sometimes, it is a 100% windows issue causing it. I had 1 friend who had it and reinstalled Windows and the problem disappeared.
    You can try this: https://helpdesk.flexradio.com/hc/en-us/articles/205665325-How-to-Repair-the-FlexVSP-Virtual-Serial-Port-Driver
  • Didier F6DXE
    edited February 2024
    Hi,
    I found the problem, there was another vsp manager loaded.
    I did remove the flex vsp manager and the other one.
    Restarted windows.
    Did a new installation of the flex vsp in the proper C:\applications directory.
    Restarted windows and everything works ok now.
    Restarting windows between processes is needed to clean the windows stacks
    Thanks for your help
    Didier (****)
    F6DXE
  • Ken Wells
    Ken Wells Community Manager admin
    One rule of good operation:
    ALWAYS close CAT before restarting your computer, and ESPECIALLY before allowing Windows to auto-reboot the computer after Windows Updates.
    Sometimes Windows Update's "auto-reboot" does not do so "gracefully."
    That explains a lot.
    I had a problem with the Icom drivers a few years ago. And, I had been using the Eltima software.
    I eventually had to rebuild the computer from scratch to solve the problem even though I had uninstalled anything to do with the serial ports.
    thanks for sharing.
