Proposal: QSO recording stream
Let's revisit this.
You can record all the audio tracks today by using DAX and VoiceMeeter
- One channel is on the DAX audio channel, such as RX1
- On the other channel, record the Mic Stream
Would that work for SSB?
And, as that was asked a long time ago, I will be honest and tell you it is on a list but it is near the bottom as there is only a handful of requests for it.
CW Sidetone being on a DAX stream is high on the list. Sadly, just not high enough as some other more critical issues. We appreciate that lives a big hole in things.
Mike, thanks for your reply. Yes, I know that there is a DAX channel for the mic but that is not so useful to me as a 100% CW operator. It is a glaring omission that there is no equivalent DAX channel for CW sidetone. It's extraordinary that it could ever have been thought unimportant so my suspicion is that it was just a mistake not to include it. It cannot be a big deal to add the feature.
Well, you say that few people seem to want it and that may indeed be so. I am disappointed that the initiative to fix such an extraordinary omission cannot seem to gain traction simply by virtue of it being just that.
Since all audio, including CW sidetone, is present on the headphone jack:
Connect to this jack with a Y shape audio splitter.
Plug your headphone/earphone on one side of the splitter.
On the other side connect a ground noise loop isolator. These are cheap, 7 euro in Ireland and work well.
Then connect the isolator to your computer to the line input or microphone input. I prefer line myself.
On Windows settings, select the correct audio source.
For recording I use QSorder software as its free and easy to set up. Make a desktop shortcut to qsorder.exe with the target: qsorder.exe -P 12060 -C
This option allows me to record one hour of QSOs on a single .mp3 file. You can of course record for any duration and the quality is good for SSB as well as CW.
That's just a kludge to get around the omission of a CW sidetone DAX channel. It's what I have been doing for the past eight years and it's a poor solution for all the reasons already discussed.
But it works and the files are acceptable for those contests that require them or for your own specific use (like I could to prove a good CW QSO with the recent Swains operation). It is not a poor solution but an alternative solution. One that can be used in the interim that other readers on here might have not have considered. Isn't the forum for sharing experiences? It consists of only a couple of parts and an audio lead. Those that need to record but feel some more years' wait for Flex is not optimal might like to try it.
The emerging technology is software integration and we're just scratching the surface in cloud and AI for ham radio. EVERYTHING to or from the air interface needs to be reflected in a digital stream. The company that does this first (including metadata) will have a commanding advantage for competitive contesting. Standards would make it even better!
- 383 Community Topics
- 639 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
