WINLINK HF Radio Email
I have been trying to figure out how to get WINLINK working on my 6700 so I can send and receive Email messages to my Friend who is on a sale boat in the gulf of Alaska but Tim's 10 year OLD instructions are not applicable any longer because the software referred to is Deprecated and not available any longer.
Has anyone been successful in getting WINLINK or other HF Packet EMAIL type software running with the software available these days?
MANY YEARS ago before everyone and there Dog had the Internet and Email now I was one of the few that ran a HF / VHF Email gateway BBS, man that was a long time ago and so much has changed since then.
Bret/WX7Y
Have you seen this old primer from Tim at Flex?
These should point you in the right direction.
Yes and as I referred to in my original post that Tim's instructions are 10 years old and the instructions are not applicable any longer because the software referred to is Deprecated and not available any longer.
I added a few more links to my reply Bret. Good luck and let us know what you discover.
Thank you John, I will check that out, I guess I should have commented that WINMOR is no longer there as a option, I will try VARA HF 4.0.6
Thank you very much
I think I got it going John, thanks for the extra Links
73's Bret/WX7Y
Another question, When VARA HF switch's bands the DAX RX fails and goes yellow and I have to manually stop and start that DAX RX channel, is this with something I have set wrong or a problem with DAX?
Thanks again John
I’m just guessing… I can’t imagine that it would do that if you are using a single slice. If you are on a single A slice, and that slice is set for DAX channel 1, then it should still be set for DAX channel 1 after changing bands.
Are you testing with a single A slice?0 -
It seems to be something on my Desktop Computer, I installed it on my Laptop and it is solid as a rock, I have changed bands many times and DAX has not disabled itself.
I really don't need HF on the Desktop anyway unless I loose the internet.
I am running one Slice A and DAX CH1
Take care and thanks again for the information
- 363 Community Topics
- 624 The Flea Market
- 8.1K Software
- 69 SmartSDR+
- 420 SmartSDR for Mac
- 270 SmartSDR for iOS
- 253 SmartSDR CAT
- 188 DAX
- 379 SmartSDR API
- 30 Aurora
- 233 FLEX-8000 Signature Series
- 932 Maestro
- 909 Genius Products
- 329 Tuner Genius XL
- 120 Antenna Genius
- 291 Shack Infrastructure
- 204 Networking
- 447 Remote Operation (SmartLink)
- 771 Peripherals & Station Integration
- 989 Third-Party Software
