FOOTSWICH FOR A REMOTE FLEX RADIO
How to connect a footswitch to my local PC to enable PTT on my remote Flex6400? I have a USB microphone connected to my local PC. A footswitch is better than operating a PC mouse. Thank you!
Best Answers
Anything USB-connected that can sense a switch closure and then send a CAT command or serial port control signal to the Flex will work. My own solution to this is the CTR2-Micro from Lynn KU7Q. There are a few others, including of course homebrew/build-your-own.
To Ted and Mike. Thank's for fine info. For sure I will go for a solution like these 👍️
73/Leif - LA9BM
SmartSDR/SmartSDRCAT has this function embedded already,
If your computer has a serial port, you do not need any extra hardware otherwise just use a USB to serial adapter and configure SmartSDR CAT to enable the PTT over serial.
Connect the footswitch between RTS (or DTR) and ground or CD accordingly to your SmartSDRCAT configuration.
Very well documented in the SmartSDR CAT User Guide.
Super simple.
73, Max
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 947 Genius Products
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
