No PTT on IOS display
I have access both local IT and through web. I can change all the setting and all received great however there i no PTT button.
How do I get the PTT button to show up?
Walter, 73 W9KJO
What does Marcus say?
Can you post a screen shot?
Do you have a Transmitter assigned to a slice? Just a wild guess.
I think you have to turn this function on in settings.
How do I turn it on in the settings.
I had to select my radio when I started the app. Would that assing the radio to the slice? How can I receive without the radio on the slice?
I have looked through the setting for a place to turn on the PTT but I cannot seem to find the correct setting. Where would I find such?
Walter, W9KJO 73
Did you look at the user guide? Section 3.7
Once again
use youtube and manual..it is all there
but
on main view for VIEW you wil see PTT as part of main menu pul down
just select PTT and you will see a small PTT button appear
touch and it goes in to transmit and touch again to turn of transmit...it it in toggle mode
you will see the PTT button turn RED and a RED parameter around the screen
Paul K3SF
Thanks every body. That has it.
Funny how something like view can be right in front of you and you just not see it.
I tried youtube and it did not help
The manual I have is very different from the one posted here. I wish I could download this one but I did save the link.
I now have a Ptt switch.
Walter 73 W9KJO
In App Settings it's PTT Toggle. Turn it on.
The Ptt Toggle did not put the PTT on the screen. It was in the View menu.
Walter W9KJO
Tap the flag and it should popup. Sorry.
I have printed off all my manuals, and have them in coil binders, still couldn't find the answer to the same issue. I found the answer here.Thanks for asking the question.0
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
