Smart link not connecting After Upgrade to 3.6.8
Vindelnero
Member ✭
After the update when trying to connect to my radio remotely Smart link sees the radio but fails to connect. Any thoughts or suggestions would be greatly appreciated.
I would submit a help desk ticket.
Whenever I hear this symptom, I tell the customer to do the following:
- Reboot the Radio
- Reboot the router/internet modem
- Turn the firewall off on the PC or if you use the firewall, make sure the Firewall rules are correct.
This is very key. Every version of SmartSDR is a 100% different program installed on your PC. This makes it easy to change versions if you need to. You do have to make sure that your firewall rules are correct for SmartSDR v3.6.8.
thanks Mike I'll give it a shot when i return to the home QTH this weekend.0
If you still have an issue when you get back, please open a support ticket and they will get you sorted out.
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 268 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
