AG not working with B2BCD
I have B2BCD installed and working. When I switch bands it sees the correct band. However, when I connected to the AG I am getting strange results. I have tried two radios and both are giving me the same results. Radios are IC-7300 and ANAN G2. When I select the bands (see below) the AG switches to the band after the equals sign. For example, when I select 160m on my radio I get nothing, 80m gives me 80m, 40m gives me 80m... and so on. What am I doing wrong? This one is really driving me crazy.
160 = nothing
80 = 80
40 = 80
30 = 30
20 = 30
17 = 17
15 = 17
12 = 12
10 = 12
6 = 6
Welcome!
  • Member, Unconfirmed
    Answer ✓
    Hello KL5RLR,
    I am Dragisa from 4O3A, apologies for the slow reply, we were out of office most of Jan.
    It appears that one pin on the AG is not working, if you look at the manual, page 24(25) you will find a BCD table: https://4o3a.com/images/downloads/antenna_genius/documentation/AntennaGenius_User_Manual_v4-1_Rev1.pdf
    Everything you described is explained by the Band A pin not firing up, you are right, it's stuck in a low position.
    You can test the other BCD port on the AG if possible?
    Depending when you bought it you can send it in for warranty, it seems like a hardware issue.
    Dragisa 4O9ITT
