can multiflex run as a true m/2 on a flex 6600?
ne9u
Member ✭
First time i've tred it tonight and best i can do is get it to behave like an so2r with lockouts. Is there a way for two transmitted signals to occur on 2 different bands at same time? Like in a m/2?
Hi, you only have one TX path and 2 RX, so TXing 2times at the same time is not possible.
tnx. I realized this after asking the question. I guess the advertising for multiflex is misleading...."With multiFLEX you can slash the cost and complexity of your multi-1, multi-2 or multi-multi contest station by utilizing a single radio for two operators."0
There are many contest stations using MultiFlex with 2 operators and a single transmitter very successfully.
I think it depends on what you want. I can imagine scenarios where this is a good fit. Sure, a little more coordination is needed if you have a CQing station on one band and a S&P on the other. For just hunting down Multis this is not a problem at all. A complete and equivalent substitute for 2 TRXs it will not be. But considering that you need two of everything for what you get with the Flex setup is still amazing.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 449 SmartSDR for Mac
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 313 FLEX-8000 Signature Series
- 980 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 830 Peripherals & Station Integration
- 145 Amateur Radio Interests
