Using the FreeDV application on a PC
These are some very very high level screen shots of my setup.
After downloading and installing FreeDV, you need to configure 3 things.
Audio
PTT
CAT - not super required.
I got 2 done:
Audio Input to computer
I am going to show the advanced window for Audio and only the radio side is highlighted.
I assigned DAX Audio RX 1 to the slice I was using. This is the INPUT to the FreeDV program.
On the bottom half, pick your speaker or maybe a USB headset. This is the part YOU listen to. (I use a Mixer, so it is VoiceMeeter Aux Input). Yours will be different.
Audio Output back to the Radio
The top part of this box is to highlight your PC Microphone.
PTT Config
I didn't use Hamlib yet, and went the easy way.
Configure a PTT Port in SmartSDR CAT.
In this example, mine is COM11 on Slice A with RTS highlighted.
On the Radio, you want to be in DIGU Mode
Just like in DIGU modes such as WSJTx
- TX Stream DAX on in SmartSDR DAX
- TX DAX on in SmartSDR
FreeDV setup is exactly the same as setting up WSJTx, FLDigi, etc.
For CAT control, you will need to get Hamlib running (I haven't done that yet).
This should get you going enough to hear some QSO's.
(I have yet to make a QSO, but maybe in a day or so)
73, Mike va3mw
Hi Mike:
Just followed your instructions with your PTT instructions. FREEDV is now operational. Thanks for posting!
Bob WB0VGD1 -
Mike,
Can you share your VoiceMeeter settings for FreeDV?
Mike Geitner
K9MWG
Thank you for your interest in training on VoiceMeeter. Indeed, VoiceMeeter setups can vary greatly, as each user's needs and configurations are unique.
It's essential to have a good understanding of the fundamentals, such as Audio Inputs, the BUS system, and Outputs. This knowledge will not only enhance your experience with VoiceMeeter but also help you troubleshoot effectively if any issues arise.
I recommend exploring the variety of tutorial videos available on YouTube about VoiceMeeter. These resources are quite comprehensive and can provide valuable insights tailored to different levels of expertise.
Hi all... I have hamlib installed and have CAT control of the Flex working via this config:
I couldn't find/remember the default hostname, so I just put in :port (in my case :5002) and it seems to work fine. My Flex tho, is directly connected to my PC. Hope this helps...
I note at the bottom that it will also work with OmniRig, so that's also worth a try. I use OmniRig (old version) to connect the Flex to Log4OM.
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
