Since updating to 3.5.9.22963 Have an Unhandled Error when shutting down. ????
How can I get rid of these Unhandled Errors? I'm also getting two of them when shutting down CAT.
Please open a support ticket. This UHE is somewhat unseen, so odds are we can get it resolved for you.
The tech support team will have more details.
I had a similar error on my laptop when closing SmartSDR. The issue occurred because I had a CAT port (via USB to serial adapter for PTT keying of the radio) and that cat port didn’t exist because I did t have the USB device plugged in at the time I was running SmartSDR.
This problem didn’t occur on earlier versions of SmartSDR. I opened a ticket for this, worked with Tim on it, and he created bug ticket SMART-9691.
The same error forced me to control tht USB - Comport and the USB to Serial converter in Device Manager. Both showed device not migrated. More installation needed. This happened as I installed a new COM for Winkeyer and added it to SmartSDR CAT. Finally I deleted this COM Port in SmartSDR CAT and all was running, exept the Winkeyer. HI.
- 391 Community Topics
- 665 The Flea Market
- 170 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 66 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
