Since updating to 3.5.9.22963 Have an Unhandled Error when shutting down. ????
  • Bikermaninphx
    Bikermaninphx Member ✭✭
    How can I get rid of these Unhandled Errors? I'm also getting two of them when shutting down CAT.
    Please open a support ticket. This UHE is somewhat unseen, so odds are we can get it resolved for you.
    The tech support team will have more details.
  • K9YK
    K9YK Member ✭✭
    I had a similar error on my laptop when closing SmartSDR. The issue occurred because I had a CAT port (via USB to serial adapter for PTT keying of the radio) and that cat port didn’t exist because I did t have the USB device plugged in at the time I was running SmartSDR.
    This problem didn’t occur on earlier versions of SmartSDR. I opened a ticket for this, worked with Tim on it, and he created bug ticket SMART-9691.
  • Detlef
    Detlef Member ✭✭
    The same error forced me to control tht USB - Comport and the USB to Serial converter in Device Manager. Both showed device not migrated. More installation needed. This happened as I installed a new COM for Winkeyer and added it to SmartSDR CAT. Finally I deleted this COM Port in SmartSDR CAT and all was running, exept the Winkeyer. HI.
