Using the accessories plug for the microphone input on 6400
If I use the accessories plug for the microphone input, does it bypass the preamp, EQ, etc...
Best Answers
  • Craig_KØCF
    Craig_KØCF Member ✭✭✭
    Answer ✓
    The Accessory connector does not have a microphone-level input. From the 6400/6600 Hardware Reference manual:
    "7.6.1 Pin 1: Line In
    This audio line input can be used to feed consumer level (-10dBV) audio into the transmitter. Refer to the SmartSDR documentation for information describing how to enable this input, and what configurations are available."
    I believe that high-level inputs do not allow use of EQ, and certainly would bypass the mic preamp. I hope this is the information you were seeking...
    73, Craig KØCF
  • Ken Wells
    Ken Wells Community Manager admin
    Answer ✓
    1) The output of a mixer. -- But it would be better to use the 1/4" BAL input on a 6600/6500/6700 or the 1/8" TRS "Pseudo-Balanced" input with a mixer, rather than the unbalanced AUX line-in port, in order to take advantage of the noise resistance of the balanced lines.
    2) Some external modems can provide a consumer level audio output.
    Answer ✓
    Any audio equipment that has a line out with a -10dbV maximum signal.
    You'll have to check the specifications for any mixer you might wish to use. It will specify it in their documentation.
  • N2YKX
    N2YKX Member
    OK, thanks for the response. Any guess as to what "consumer level" equipment Flex is expecting to input in pin 1 of the accessories plug?
    -10dBV
  • N2YKX
    N2YKX Member
    Mike VA3MW - Can you give me an example of what "consumer level" equipment might be? If it's not a microphone, just curious'
  • N2YKX
    N2YKX Member
    Thanks Ken, that answered it.
