Power Genius XL RF Early Warning
I'm trying to use my Icom 7610 today with the Power Genius. On CW when I attempt to transmit I get the warning "RF Early" warning. Using the latest version of software...SmartSDR and the Power Genius. I have set the transmit delay to 30 ms without any change in the warning.
The Icom is connected via CI-V and the Tuner Genius is in line with low swr. Does anyone have a suggestion of what maybe is causing this issue.
The flex works fine...just the Icom.
Try increasing the delay in increments to help explain what is happening.
Bill W9JJB
PS on 60m be sure to decrease the high end cutoff below 3000hz and don’t use the split or fake it. Either of these two things could allow TX outside the permissible band restriction. Flex would then inhibit TX.
The delay is at the maxed to the limit...thanks for the response...
Hi Ronald,
You may wish to open a support ticket for this.
m
Thanks for the advice Mike...
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
