How to get panadapter B out of 15 meter band.
6600M being operated independently, no computer.
Do just as you do with the main slice receiver. Touch the frequency display. The band selection box ( along with other selections) will pop up. Touch the band you want. That will change the band for Slice B.
If you haven't done so, download the 6400M/6600M manual from Flex Radio's website. Everything you need to know to operate the 6400M is in the manual.
Tap the R Side Frequency and then hit the band change that pops up.
James,
Many thanks for the kind advice. Alas, I've tried your suggested method several times including variations; nothing will change B panadapter out of 15 meter band. I am verifying B is active before trying to change bands. Tried inactive also but, of course, that doesn't work either. I have a well-used hard copy of the official manual on hand but find no help with any of the info there.
Perhaps it's time for a soft reset but trying to avoid that if I can. I notice than when I do try to change band in B, the AF gain increases but band does not change. Probably a simple fix/explanation for all of this. None are so blind as those who will not see!1 -
I created a support ticket for you.
John,
Is this radio new to you? Or have you been using it without problem until today? You can try a full reset to see if that clears the problem. That is what the Help Desk will probably suggest you try to see if that clears the problem. If that doesn't work, they will offer you some other things to try. The Help Desk is your best bet to find the problem.
Any updates?
- 256 Community Topics
- 491 The Flea Market
- 7.4K Software
- 137 SmartSDR for Maestro and M models
- 333 SmartSDR for Mac
- 241 SmartSDR for iOS
- 225 SmartSDR CAT
- 162 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 789 Maestro
- 42 FlexControl
- 837 FLEX Series (Legacy) Radios
- 737 Genius Products
- 394 Power Genius XL Amplifier
- 256 Tuner Genius XL
- 87 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 119 Contesting
- 588 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 815 Third-Party Software
