WSJT-X, DAX RX Gain & AGC-T
Try this
First, set the AGC-T with a quiet spot on the band.
Now, with FT8 signals, adjust the RX Level so that the received signals are in the correct place which is about 1/2 up the scale while decoding signals.
That part is not really that critical on a FlexRadio thanks to the Dynamic Range the radio has. On older radios, it is more critical.
Thank you, Mike. I ended up landing with a DAX RX Gain = 56, and AGC-T = 11. I did not expect to turn the AGC-T that low. Seems to work.0
I should not interject, it is your system, but you are working on an incorrect premise. The WSJT-X meter measures a dB signal input and not noise. The level to aim for is mid-point during receive on an active FT8 band. It is not critical except that if you test it against number of decodes, you will see that circa 80dB plus will reduce decoding. Mid point should equate to a DAX RX gain level of about 35.
AGC-T should either be set according to the instructions provided by Flex, completely out-with FT8 and best done on SSB, or else set automatically using SDC. Either way, usually the AGC-T setting is around 50 unless you have an exceptional noise environment.
Your settings will look good from far, hence your belief that they "seem to work" but they are far from good. Try a few more experiments, especially noting the above figures. I think you will see better results. If not, nothing lost.
- 390 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 947 Genius Products
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
