SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
WSJT-X, DAX RX Gain & AGC-T
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsTry this
First, set the AGC-T with a quiet spot on the band.
Now, with FT8 signals, adjust the RX Level so that the received signals are in the correct place which is about 1/2 up the scale while decoding signals.
That part is not really that critical on a FlexRadio thanks to the Dynamic Range the radio has. On older radios, it is more critical.
Thank you, Mike. I ended up landing with a DAX RX Gain = 56, and AGC-T = 11. I did not expect to turn the AGC-T that low. Seems to work.0
I should not interject, it is your system, but you are working on an incorrect premise. The WSJT-X meter measures a dB signal input and not noise. The level to aim for is mid-point during receive on an active FT8 band. It is not critical except that if you test it against number of decodes, you will see that circa 80dB plus will reduce decoding. Mid point should equate to a DAX RX gain level of about 35.
AGC-T should either be set according to the instructions provided by Flex, completely out-with FT8 and best done on SSB, or else set automatically using SDC. Either way, usually the AGC-T setting is around 50 unless you have an exceptional noise environment.
Your settings will look good from far, hence your belief that they "seem to work" but they are far from good. Try a few more experiments, especially noting the above figures. I think you will see better results. If not, nothing lost.
- 419 Community Topics
- 718 The Flea Market
- 228 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
