Interfacing F 6700 with DX Engineering RTR-2
Mr Radio
Member ✭✭✭
I consider interfacing both units. Is there someone who has done it already?
In RTR-2 manual there are sevaral remarks made about a proper PTT connection.
All comments will be appreciated.
Tom
It has been a long time since I used one, but you just need to connect the RCA PTT to any of the PTT ports on the back of the radio and then go into TX settings and turn that TX port (1-3) on for the bands that you may use the RTR-2 on.
TNX, OM Mike,
Your response answers my question.
Tom
The other thought if you are just using a single RX antenna, you could just use the RX antenna port. On a 6300 you can use the XVTR port.
Unless you are doing a few more things.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
