Interfacing F 6700 with DX Engineering RTR-2
Mr Radio
Member ✭✭✭
I consider interfacing both units. Is there someone who has done it already?
In RTR-2 manual there are sevaral remarks made about a proper PTT connection.
All comments will be appreciated.
Tom
It has been a long time since I used one, but you just need to connect the RCA PTT to any of the PTT ports on the back of the radio and then go into TX settings and turn that TX port (1-3) on for the bands that you may use the RTR-2 on.
TNX, OM Mike,
Your response answers my question.
Tom
The other thought if you are just using a single RX antenna, you could just use the RX antenna port. On a 6300 you can use the XVTR port.
Unless you are doing a few more things.
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
