smart link failed to connect
k3qh
Hi,
I can't connect and getting this message. It was working perfectly until now.
thanx, Stuart
this should help explain things.
Or, just reboot your radio and your router and see that fixes it.
I got it registered but still will not test.
Registering and passing a test are 2 different things.
The first is used to identify you. The test makes sure the right communication packets are making by your router to the radio. If the plumbing is busted, it will fail a test.
Mike thanks,
so it is possible my router can be blocking the communication?
- 394 Community Topics
- 670 The Flea Market
- 176 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 80 Aurora
- 320 FLEX-8000 Signature Series
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
