smart link failed to connect
k3qh
Hi,
I can't connect and getting this message. It was working perfectly until now.
thanx, Stuart
this should help explain things.
Or, just reboot your radio and your router and see that fixes it.
I got it registered but still will not test.
Registering and passing a test are 2 different things.
The first is used to identify you. The test makes sure the right communication packets are making by your router to the radio. If the plumbing is busted, it will fail a test.
Mike thanks,
so it is possible my router can be blocking the communication?
- 390 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 58 Aurora
- 974 Maestro
- 947 Genius Products
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
