smart link failed to connect
k3qh
Hi,
I can't connect and getting this message. It was working perfectly until now.
thanx, Stuart
this should help explain things.
Or, just reboot your radio and your router and see that fixes it.
I got it registered but still will not test.
Registering and passing a test are 2 different things.
The first is used to identify you. The test makes sure the right communication packets are making by your router to the radio. If the plumbing is busted, it will fail a test.
Mike thanks,
so it is possible my router can be blocking the communication?
- 387 Community Topics
- 438 SmartSDR for Mac
- 203 DAX
- 385 SmartSDR API
- 52 Aurora
- 969 Maestro
- 944 Genius Products
- 810 Peripherals & Station Integration
